Thanks for clarifying that. 25K to 43K is a massive jump in and of itself.
Originally Posted by wag123
Originally Posted by paulri
Wag123, was that 42 PSI cold or hot?
When you did go just to 40, but found it unsatisfactory--was that because there was no improvement in tire wear, or just not enough from your perspective.
Not trying to pester you, but I've never heard anyone advocate doing this before, and I've suffered enough tires (I think all of them) getting only 50% of the warranty life, that I"m thinking of trying this.
Tire pressures are always quoted, checked, and adjusted when the tires are cold.
I went from 35 PSI to 40 PSI on my second set of tires. Tire life went from 25k miles to approx 43k miles, but I was still seeing a small amount of higher inner and outer tread wear on the front tires, indicating under-inflation.
I went from 40 PSI to 42 PSI on the Primacys. They lasted over 50K miles, tread wear was nice and even across the front tires, but I replaced them due to rubber deterioration before they wore-out. The Michelin Primacys came with a 60k mile warranty, I suspect that they would have lasted 60k miles if I kept them on the van until the tread was worn-out.
I think JJ meant that his MPG and tire wear improved, so did mine.
