Collinite 476 or liquid 845 which is the best?
Northeast
I am about to order some Collinite nuby wax. However, which of the two is the best 476 paste or 845 insulator. I sealed already with some DG 101, and I will be following up with some DG 111 tommorow. But I opt to top it all off with some Collinite. Thanks in Advance!
I like 845IW but I hear 476 lasts longer. With the already amazing durability of 845 I'll prefer waxing slightly more often because it is easier to use. The 476 can be harder to use plus from what I read 845 makes paint look better than the 476 without too much of a hit in the durability.
I heard they're about the same in looks, but the 476s last longer. I find the 476s easy to put on and remove and that's on a black car. Surface prep makes all the difference. I just spent 3 hours last weekend clay, polish and then 476s.
The new 845 doesn't seem to have as much solvent since it is VOC compliant. Doesn't smell very strong to me either, turtlewax cheapo green wax now that smells like it has solvents.
Is this a good 3 step process to use??,you would think the
coll would strip the DG????
