I also used to think it was normal for the filter to be empty when I removed it, until I stopped using Frams and found out that other brands didn’t drain out like the Frams always did.
Frams have 2 problems regarding cold starts-
1-the adbv routinely draining out and causing a few seconds of tapping until pressure builds up, (depending on the vehicle not always audible) and
2- the problem that I was describing…valvetrain rattle that occurred for several minutes until the oil warmed up/thinned enough to flow better.
Both problems went away for me when I stopped using Frams.
AS usual, to correct MORE Filter Guy Spin……
As for the statement-
“Yet, he changes to a more restictive media than what is in the Fram and his problem is "solved".”
I never said that…I said
“Only when I read that Frams caused that noise routinely did I even think about changing. I bought a new filter, (ACDelco at that time) changed the filter only- not the oil, and the noise never re-occurred.”
I have used several brands of filters since then…all were better than the Frams.
Filter Guy- stop trying to spin everyone’s words just to fit your purpose, which as far as I can tell is just to confuse the issue and deflect blame away from cheap ineffective filters.
You are the one that argues for the sake of arguing.
