Whats kind of saddening is the start cycle of modern cars that prioritizes cat warm-up. I start my silverado and get like 15 seconds of 1500 rpm idle immediately. Can’t be good for things…
Yes! Then post pictures so we can have another sludge or not thread.Check underneath your oil oil cap and then the dipstick for any oil emulsification or mayo.
Yep. If it was a problem every automatic in MN would be dead.It’s been getting down to 0°F here almost every night. I’m not used to driving an automatic transmission in the cold. My practice in the past has always been to let the engine run for however long it takes for it to drop out of high idle and then drive gently until it warms up. I assume an automatic isn’t any different?
Usually the block heater cord would be routed out through the grill or front of the vehicle. Never seen a cord on the rear unless someone did a special install?We just picked up a new Chevy Equinox yesterday looked in the back hatch and a couple of wires in the back. Just realized it came with a engine block heater option not sure I'll ever use it
No the cord was being stored in the hatchback the plug must be in the front grillUsually the block heater cord would be routed out through the grill or front of the vehicle. Never seen a cord on the rear unless someone did a special install?
It’s not even 9 am and at 54°F … heading to 80°F …It’s official. Baytown, Texas is freezing.![]()
I've sat in -14 and that was cold enough.Today's temp here is currently -17F, the high for the day. After parking at work I sat to watch the oil and water temps as I was curious as to the heat dissipation rate at idle. When at idle, my oil was dropping in temp (from a high of about 160F) roughly 4 degrees per minute, and the coolant was dropping nearly 10 degrees per minute. On days like this the thermostat never opens. Mind you, this is on a 2.0L EA888, so small displacement and the coolant is routed through the integrated exhaust manifold for efficient warm-up. Yes, I will start it and let it warm up for 15 minutest today before I leave...anyone that says otherwise and is in the "just get in and drive" camp has never sat on -17 degree leather. The joys of the North!
Baytown Texas is the Canary for the USA. If it’s freezing in Baytown, it’s cold in the USA.It’s not even 9 am and at 54°F … heading to 80°F …
Too bad I’m changing a toilet and washing machine today …
I took a snowblower and made a nice clear wide path on the lawn around the side yard so the dog can do his business easier. At 11 years old, sort legs and arthritis that's important.I think I might have done mine on a Tuesday too ... as recently as September.![]()
My 1989 Mazda 323, fuel injected, started at 2400 RPM then revved to 3k or more for minutes. Never had a car since that was that bad. I used to put it in gear then let it lug itself around to "save the engine" from itself.Whats kind of saddening is the start cycle of modern cars that prioritizes cat warm-up. I start my silverado and get like 15 seconds of 1500 rpm idle immediately. Can’t be good for things…
