It is -33 F in Saskatoon this morning.
“ Running back to Saskatoon”
In my 2016 Civic it definitely makes the coolant warm up faster with the temperature set to low and I’ve checked it two days in a row driving the same route and starting off at the same outside temperature and making a note of where I was when the gauge hit the first bar. But I can definitely understand how that might not work with other cars with more sophisticated climate control setups.I do the same with the fan - off initially, and then on its lowest speed until the coolant temperature comes up.
In my older vehicles, coolant flow to the heater core was regulated by a valve in one of the heater hoses. I can see how closing the valve to restrict flow to the heater core would allow for a faster warm-up.
However, every car I look after now has full-time flow through the heater core, with the heater output regulated by the blend-air door.
Our van has a Scan gauge - I think I'll try turning the temperature right down, to see whether the coolant temperature increases faster. I don't expect it to, but it's worth trying.
That is interesting and proves the best way to warm up an engine is to drive it , not idling it in the driveway for 20 minutes like so many people like to do.. When at idle, my oil was dropping in temp (from a high of about 160F) roughly 4 degrees per minute, and the coolant was dropping nearly 10 degrees per minute.
No it won’t. Depends what states use. I live 1 1/2hrs from coldest basin in lower 48. It is officially high desert. Super dry air, extreme cold (dropping overnight locally to -50) and county maintenance whose moto is: “it is always sunny, that will do it once it stops snowing.”I think everyone overthinks a little. I don't think your car cares much what you do short of starting and putting it in gear and going full throttle. Even then I wonder if it would matter much. Where it is -20 your car will rot from the salt before you wear out an engine from cold weather damage
This morning it is 10 degrees (will drop during the day below 0). Taking kids to school, every other driveway has cars idling.That is interesting and proves the best way to warm up an engine is to drive it , not idling it in the driveway for 20 minutes like so many people like to do.
Hey, try to guess who sang it.It is -33 F in Saskatoon this morning.
“ Running back to Saskatoon”![]()
Not much!Yes every time it gets a little on the cold side I think, "It would be worse if I lived in Winnipeg..."
Or an oil pan heater, or a Webasto/Espar type of heater. Block heater help, but IMO they aren’t ideal.Anyone who starts vehicles regularly below 0 and keeps vehicle outside, should invest in block heater.
Too subtle for this crowd.Hey, try to guess who sang it.![]()
Where were you in '72.Too subtle for this crowd.![]()
In the summer of '74 I pretty much played "Best Of The Guess Who - Volume 2" to death.Where were you in '72.
I used to get in and drive as soon as my clutch wouldn't stick to the floor and SLOWLY come backToday's temp here is currently -17F, the high for the day. After parking at work I sat to watch the oil and water temps as I was curious as to the heat dissipation rate at idle. When at idle, my oil was dropping in temp (from a high of about 160F) roughly 4 degrees per minute, and the coolant was dropping nearly 10 degrees per minute. On days like this the thermostat never opens. Mind you, this is on a 2.0L EA888, so small displacement and the coolant is routed through the integrated exhaust manifold for efficient warm-up. Yes, I will start it and let it warm up for 15 minutest today before I leave...anyone that says otherwise and is in the "just get in and drive" camp has never sat on -17 degree leather. The joys of the North!
