It should be pointed out that a/c is a heat pump--it is taking heat from the interior and pumping it outside. Thus the fans have to kick it on to dissipate that heat.
it's kinda cool if you think about how it works. How do you take "heat" from inside a car and put it outside--when the inside of the car might be 70 and outside 90? Answer: the temperature of the refrigerant goes way above and below either.
I took a class or two in thermo in college; lots of fun stuff there.
