I got the harbor freight $12 special but work on mostly economy cars. (Read: soft springs) Has cut, not machined, threads; keeping them lubed is a big part of the bargain.
Sometimes you can actually use the car as the spring compressor with a jack under the control arm.
If the car has an upper arm, you can also loop a chain around it and the underside of the jack, forcing the spring to compress with jack movement.
