Coil overs installed at a professional shop. Image shows a wire embedded between the top hat and upper coil over mount bracket. Unable to pull out wire or see the other end. Did the top hat deform around the wire when the bolts were tightened? If not, could one or two bolts eventually loosen because the top hat does not bear directly against the bracket?
