clutch slipping... coincidence?
Originally Posted By: Clevy
Synthetic oils don't reduce friction any more than conventionals do.
Technically speaking Synthetic oils uniform size molecules reduce friction and increase
flow more than straight mineral oil variable size molecules...
Uniform size molecules of synthetic oil
Variable size molecules of refined crude
Originally Posted By: IndyIan
It was 5W50 but back then it had the VW 502 or 505 spec, which I seem to recall reading somewhere isn't a good spec for a wet clutch.
My atv is a 01 suzuki kingquad 300, so it might have 20hp, but then it also spends alot of time moving 2000lbs of quad, rider, and trailer up my hills.
Just look at the wide range of oils in use today and yet no one
complains about clutch slip when new... so its possible that
understanding what constitutes a "good spec" has more to do with
clutch age than oil in question...
I just ran Bel-Ray 10W40 motorcycle dino before that. I don't know if my clutches are all that worn though even now, as they don't slip much as I always match ranges to the useage. So even starting to move a full load on a grade only takes 1/3 throttle in the lowest gear.
