so the new saturn has a clunk over sharp bumps. both wheels will do it but it only happens when one side hits a bump if both sides hit a bump at the same time is wont do it. i checked tie rods, strut mou8nts, stabilizer bar bushings, ball joints and control arms. i jacked up the whole front end and checked everything and jacked up one side at a time on control arm to checked ball joint i cannot find play anywhere. motor mounts are all good to and rack mounts are good. so what gives?
