Hello
Is there a good do it all (clean, lube and protect) that I can pick up locally?
Rem oil comes to mind as I've seen it at WalMart and I emailed Ruger (as I have a P95) and here was the transaction:
Do you recommend a certain type of cleaner/oil for the P95. All I saw mentioned in the manual was some solvent powder. Can I just use Rem Oil as both a cleaner and oil? I would really like to avoid the powder if there is no benefit as it might be difficult to remove it all. My last gun used Breakfree CLP for both cleaning and oiling. thanks Response: Yes, you may use Rem Oil on your firearm. We recommend that you do not use any type of solvent on the frame. But would suggest you try Birchwood – Casey’s Stock Restorer. We have found it work very well on all Synthetic frames.
I haven't seen Breakfree locally, but they mention on their webpage that it is available at several local stores. It WAS recommended by my previous gun's maker.
Also, do I need any grease or can I get away with just an oil?
thank you
thank you
