Originally Posted By: Burt
A guideline for industrial engines is not to run them continuously at more than 90 percent of rated power capacity. I assume that similar is true for cars.
So, if your car has say 200 hp, then don't run it continuously at 180 hp? That translates to perhaps something like don't run it to redline minus 500 to 1000 rpm. I don't know of anyone in real life (who still is alive) that would continuously drive like that, although I have seen some really crazy stuff in movies (eg drive, the bjourne insanity, etc).
Quote:
Most all the wear is cold starts or when you push the engine to its output or rpm limits. But look forward to comments of others. You might be a good candidate for a plug in hybrid because it will shut off the engine during coasting and recharge when braking.
I agree, I would try to keep it at least 1000 rpms from the redline (which is like 6000-something)). In my car the fuel efficiency at near wide open throttle peaks somewhere before 3300 rpm (the peak torque point) then starts to decline more and more rapidly after that peak torque point; therefore I rarely take it above 5000 (and generally under 4000 to maximze fuel ef).
If you have an automatic transmission you have less ability to control this, but I believe most automatics will go reasonable on the rpms unless you have the gas pedal almost all the way down to the floor.
For the first few minutes of driving (say 3 minutes), I try to keep the rpm's below or not much above 2000. So, after the first mile or so of a cold startup i'm really careful and aware of this. The second mile, i try to keep it under 2500; and after that I drive it as I normally would.
If your up hills are pretty much immediately after startup, then I would consider letting it idle for a minute or two and have it get a headstart on warming up.
Good point also on the hybrid; many of these have regenerative breaking and would be ideal for hills and stop and go driving.
