- Joined
- Nov 23, 2021
- Messages
- 392
How do you guys like using Clay Mitt's vs. Clar Bar or Sponge??
Hi atikovi,They are great for doing large areas quickly, and for use with iron removers. When I started using using an iron decon followed by a clay bar, I decided to combine the two. Use the iron decon as the lube for the clay bar, The only problem was the clay bar dissolved in the iron remover. Found the clay mitt suggested by someone here, solved that problem. Now I can take care of two tasks simultaneously and quicker overall.
Which iron remover did you use?They are great for doing large areas quickly, and for use with iron removers. When I started using using an iron decon followed by a clay bar, I decided to combine the two. Use the iron decon as the lube for the clay bar, The only problem was the clay bar dissolved in the iron remover. Found the clay mitt suggested by someone here, solved that problem. Now I can take care of two tasks simultaneously and quicker overall.
Clay will create minor marring to the finish, so only clay if needed and follow up with a good polish. Then put down whatever you fancy if you want protection.Great info everyone. I am hesitant about using clay on my car,...afraid I will ruin the clear coat. But my question is,...once you clayed the car what did you put on for protection afterwards? Did you do a full wax and protection, and what did you use?
