What Liquid for Claying Vehicles ?
PNW
What is your favorite liquid to use when claying your vehicles ? I would think that a quick detailing spray would be a popular choice but the only thing I have on hand is distilled water in a spray bottle and Griots 3:1 Ceramic Spray ?
I have used a good car wash soap while claying
I buy a Gallon of Meguiars Last Touch Detail Spray from Amazon. I dilute by 50% with distilled water and use it for both touch up and clay bar. Comes out much cheaper than the small spray bottles. Just buy an empty spray bottle and refill!
Thanks for the replies - I just washed and dried my car , so I’ll try the straight distilled water spray as a clay lube first .
Quick detailer or solution of ONR and distilled water.
Optimum No Rinse. +1 on that for clay lube. Really any multipurpose product that can be used for several purposes from the concentrate in various ratios of product to water are perfect as clay lube. The usage instructions will give the correct ratio. It saves a lot of money since you can make them into detail spray, waterless wash, rinseless wash and even interior cleaner spray. Distilled water is key, however. I also like McKee's N-914 and Adam's Hoseless Wash.
I have used detail spray and also a 5 gallon bucket of soapy water. The last few times I washed it first then rinsed and refilled the wash bucket with soap and clean water and used that for the clay lubricant.
Also just use soap but dishwashing detergent to strip old wax and any grease/oils off. It's a good bit of work waxing my Ram. I basically wash it 3 times in the process. I try to do it every 6 months but it usually lags that interval.
Maybe not what most would recommend, but I just put a few squirts of hand soap in some water in a spray bottle. It works great for me and I'm not aware of any additional marks I've cause.
I usually only clay before a polish anyway, so any marks would quickly be removed.
Whatever quick detailer I have on hand...Griots Speed Shine or Griots Ceramic Speed Shine presently. I've also used Zymol or Mequires quick detailers.
Tip: do the claying right after washing and before drying. That will minimize the quantity of detailer spray required.
That's terrible advice. Dishsoap dries out the clear coat fast. Use a dedicated strip wash formulated to safely strip waxes and coatings.
