Quote:
Quote:
.....The manufacturers product data sheet states that the Rotella 10w-30 CJ-4 has a flash point of 249C or 480F. So is that false than?
The USA spec sheet says 204C, the Canadian spec sheet says 249C.
The old Rotella 15W40 CI-4 VI was 141. The new Rotella 15W40 CJ-4 is 135. http://www.shellusserver.com/products/pdf/RotellaT(CJ-4).pdf .Quote:
How do the vi indexes compare from ci4's to the cj's?
Wouldn't the vi index in this case have more to do with the amount or type of vi improver used because the viscosity of the base oil "in the finished product" Years ago Amsoil made a 10w/30 had a 150 ish viscosity index and the new pao only oil was 176ish with viscosity improvers.Quote:
Quote:
...I can't share too much about why I think Rotella T CJ4 is so good because I worked for Shell last year. It is the sleeper oil for many here at BITOG that want performance at reasonable cost. WILL perform as a near synthetic (I said it Gary). 10w30 CJ4 Rotella is a wonderfully wide use lubricant.
Quote:
If they are so great then why isn't our engine supplier recommending them for the off-road equipment we produce?![]()
Quote:
If the CJ-4 is that much of an improvement, I wonder why the CI-4+ is still available for large quantity users? It appears, to me, that there must be some advantage to the 'old' CI-4+ if they are still manufacturing it. Maybe the CI-4+ 'is' a more robust oil, for those that don't actually 'need' the new CJ-4.
