More info would need to be given, but we can make some generalities.
Just about all API specs are backwards compatible for their intended application. CJ-4 would cover CI-4, but not the other way around. A "diesel" is a very loose description; we'd want to know about the specifics.
If used oil analysis are the intent, then mixing the fluids will confound some of the inputs; not that it cannot be done but it makes for odd add-packs and chemistry interactions may affect the UOA. Generally the chemistry interaction will NOT affect the equipment, however. If used oil analysis are not the intent, and just using up some old oil stock is the goal here, it's probably OK.
You give us more intel and we'll get you a better answer than "meh ... maybe.... maybe not".
