....After much research, we have concluded that the best answer when it comes to charging EFB batteries is to charge them using the AGM setting when using our
PRO-LOGIX or CHARGE IT! battery chargers. This is because the EFB construction is more sensitive to voltage than a traditional flooded battery is. Like the AGM battery type, with EFB, it is important not to exceed recommended bulk charging and absorption charging voltage limits.
As a for instance, the team at Stryten Battery, a major provider of EFB batteries to OEs and the aftermarket, recommends not allowing bulk charge to exceed 14.8V and switching to absorption charging at that point. They recommend holding absorption charge voltage at 14.8V. These instructions are similar to the charging instructions for charging AGM batteries – this is why we recommend using the AGM setting when charging EFB batteries...
