Your thoughts on these? I’ve been a Toyota fan boy since 2002…Tacomas preferably. Although Toyota quality has gone down hill it seems with TTV6. I maybe looking in to a full size that gets decent gas mileage.
I'm sure they're better sound deadening since the Cobalt days.i think there's one in my neighborhood
i wasn't prepared for Chevy cobalt turbo noises from a truck
Is there anything you like that isn't 20plus years old???i think there's one in my neighborhood
Can't order it with 60/40 front seats with fold down center console? I know it's not true center console.Hot take: It nearly makes the 5.3L obsolete.
For your typical CCSB truck, the 2.7L does everything, including towing (with isn't typical use anymore), just as well as the 5.3L. Need more power, hate fuel economy, and love the high price of premium fuel? Buy a 6.2L. Need more torque, want great fuel economy, and love the high price of diesel fuel? Buy a 3.0L.
That leaves the 2.7L and 5.3L occupying the same space. Yeah, the 5.3L now gets the 10-speed as standard but the 2.7L now gets the 2nd gen 8-speed that solved many of the issues with the earlier 8-speeds.
Unfortunately, there's one thing that is a deal breaker for me on the 2.7L. I want my full size truck to have a center console, not a bench seat, and you can't have a 2.7L with a console.
So you don't want a column shifter I assume? Because the "third "jump seat" in the center of my 2023 Crew Cab LT is very console like-except it isn't one. I have the 5.3-The motor was a ($1,595.00) option.Hot take: It nearly makes the 5.3L obsolete.
I think it's a part of GM's CSS (Cylinder Set Strategy) engine line. I believe the CSS engines are entirely a clean slate design, so I don't believe its an evolution of the old ecotec's.Can anyone tell me if this engine is an evolution of their old 2.2-2.4L Ecotec's? Probably went through a whole makeover 23 years later.
The 2.7 is a completely new design-made initially for trucks-hence the torque curve being where it is.I think it's a part of GM's CSS (Cylinder Set Strategy) engine line. I believe the CSS engines are entirely a clean slate design, so I don't believe its an evolution of the old ecotec's.
considering ive never heard anything good about the ecotecs that's probably a good thing.I think it's a part of GM's CSS (Cylinder Set Strategy) engine line. I believe the CSS engines are entirely a clean slate design, so I don't believe its an evolution of the old ecotec's.
no it's probably quieter inside the truck. i was just out for a walk and a newer Chevy truck drove past, and sounded like a turbo 4 cylinder.I'm sure they're better sound deadening since the Cobalt days.
2010-ish bmw dieselsIs there anything you like that isn't 20plus years old???
This is about the most accurate and true summary I’ve heard. I specifically did not want the center console / console shifter so this worked well for me.Hot take: It nearly makes the 5.3L obsolete.
In my experience, and from hanging out on the RV boards-with a gas motor you get 10-to 12mpg towing any sizeable weight at all. It seems to be that way regardless of motor size.This is about the most accurate and true summary I’ve heard. I specifically did not want the center console / console shifter so this worked well for me.
My long term average fuel economy is 23mpg in my 2023 LT crew cab 4x4 and that’s a mix of about 40% highway / 40% rural back roads / 20% city including a small amount of towing my 5,500lb boat.
The engine tows beautifully but as many will point out there’s no fuel economy advantage towing with the 2.7 over the 5.3 or 6.2. It just takes a lot of fuel (energy) to move a lot of weight regardless of the number of cylinders burning that fuel.
Pretty sure he isn't 20plus years old. Odd.Is there anything you like that isn't 20plus years old???
In 20k miles towing a 6000+/- lb travel trailer all over the country with the GM 6.6 gas the average is exactly 10 mpg.In my experience, and from hanging out on the RV boards-with a gas motor you get 10-to 12mpg towing any sizeable weight at all. It seems to be that way regardless of motor size.
