- Joined
- Dec 27, 2020
- Messages
- 313
38/35 nitrogen in the ex wife’s new Suzuki Swift Sport. 39/36 nitrogen in the daughter’s Suzuki SX4. 40/37 nitrogen in my BA Falcon.
Opinion, nothing but logic to back it up, yes if in straight line, no if twisty road.Hey all, is it pretty much typical (or a generalization) that the driving wheel PSIs will increase at a faster rate than the non-driving wheels when in motion?
Yep, daily here, too. But just a visual. We find that once we get a tire seated well on the rim we simply don't lose air pressure any more. These are "E" rated Michelin LTX MS and MS2's.
I have load range E tires too. They only need air when the seasons change or if there is a leak. Typically twice a year I adjust the pressure
My car has an individual readout for all 4 tires that I check often.
So do I.Originally Posted By: Astro14
Am I the only one who checks it monthly, or before a road trip, regardless of season?
I check it weekly, at least.![]()
If so equippedDon't forget the spare !
Especially for us pick up truck drivers !
It’s uncanny. My 4 tires are the same to the 0.1, when set as such, when checked weeks later. I’ve suggested it to others and they laugh as if I’m made of money getting that. I get it most wouldn’t care +/- 2 or 3 psi or simply using the nitrogen machine at costco (it does seem to be consistent).I want to thank all of you great folks for recommending the Jaco tire pressure gauges. I have 2 of them now, one on my car and one I keep at home. They are heavy duty and so accurate!
My tires change pressure obviously when it is cold. I am very OCD, so I check them frequently and have a portable inflator. I was sick and tired of wasting money at the gas station especially when it is cold, and the tire inflator machines do not work and were totally inaccurate.It’s uncanny. My 4 tires are the same to the 0.1, when set as such, when checked weeks later. I’ve suggested it to others and they laugh as if I’m made of money getting that. I get it most wouldn’t care +/- 2 or 3 psi or simply using the nitrogen machine at costco (it does seem to be consistent).
I’m like you. So I spent over $25 for a Jaco elite. I don’t even use it all the time, only when I’m at costco. And I release some pressure and make them exact to 0.1 overnight cold. I admit if a person inflates at costco it’s generally good enough. But I want it exact…and even nitrogen seems to be 1 psi per 10F. People say the benefit is it takes longer to leak through the sidewalk that’s allMy tires change pressure obviously when it is cold. I am very OCD, so I check them frequently and have a portable inflator. I was sick and tired of wasting money at the gas station especially when it is cold, and the tire inflator machines do not work and were totally inaccurate.
Yeah, It takes longer to pass through the rubber than Oxygen. It's also had the water removed, so helps prevent corrosion on the inner part of the wheel.But I want it exact…and even nitrogen seems to be 1 psi per 10F. People say the benefit is it takes longer to leak through the sidewalk that’s all
