Some Mfrs do have oil level monitors.
Since modern cars use so little oil, it probably is considered an unnecessary gauge by the rest.
you should call cadillac and tell them that modern cars use so little oil! They will laugh at you! lol
In my cts, I have an oil level sensor that tells me when I'm low on oil only when the ignition is at the "on" position, engine not running and I have to wait for about 10 seconds, before that, its not activated/nothing show up on the DIC. Also, when the check oil level shows up on the DIC, it means that I'm down to almost 3qt on a 6qt sump. That is sad.
Don't worry, I never let the oil level below the "add" on the dipstick. I check every 2 times I go for fuel, it means that I check the oil at least once a week. I tested the oil level sensor when I was doing my oil change to see if it worked. I was adding 1/2qt per 1/2qt until the message disappear.
