Quote:
Thanks, So I guess the cheap house brand oils are the low additive oils.hmmm
This subject is talked about alot on some other posts and it sounded like from the news and other sources that most name brand oils have cut way back on additives because of cataletic converter failures.
What kind of car/truck, WadeDog? Seems the consensus has been lately (by the folks in the know, that is), pushrod V-8s with fancy cams or hard running, engines that race, and in other words, conditions that lead to occasional metal-to-metal contact, can use the zinc. Adds are handy for older cars, I'd imagine, that want to get their 72 Vette up to, what, SF, or SG additive levels? They actually need it, too.
Newer DOHC 4 bangers and family car six's that aren't stressed, aren't raced, don't need the extra zinc. The turbos may need syn, or to run thicker or thinner, but they don't need more zinc. They did some pretty hideous testing, abuse really, of the engines and oil that certify API SM, and ILSAC GF4 and the dual designation means most PCMO have around 800PPM/ZDDP maximum, and those are pretty stout oils for 90% of the street cars out there, and quite without extra, third-party zinc.
Further, the zinc in SJ and SL (which you're creating with more ZDDP) levels are proving to foul cats in the long term. All that said, if you DID want to add zinc, why not run a bottle of Delo or some other diesel motor oil and at least get a balanced dose? Folks talk about additive clash created by mixing motor oil brands and grades and then here's folks creating their very own add-clash with third-party adds. Ever see the numbers on VSOT? Tons of moly, tons of zinc, tons of other stuff. Does the Colorado need it? Bet the manufacturer doesn't think so, but we all makes our choices. 777 is pretty savvy, he has his reasons, I'm sure.
Then there's the possibility you're diluting a far better base in the motor oil with the carrier oil of your additive. THAT is another subject. What kinda car ya have again?
