I’ve been on BITOG too long. I now want to change my oil.
I see many advocate using ramps. Any downside to that? I think this might make it easier to reach stuff when I need to tighten/twist, which IIRC was why I stopped changing it myself many moons ago. I have not tried on either of my two current vehicles yet.
FWIW, I would be doing this on a flat gravel driveway, although I’d obviously clear away the rock for doing this. Garage is storage at this point. The chance of me owning anything heavier than a Sienna is incredibly unlikely, so I don’t think I’d need anything more heavy duty than what I linked to, below.
I found this online: http://www.autozone.com/engine-and-vehicle-lift/ramp/hopkins-12000-lbs-rhinoramps-max/89618_0_0/
http://www.walmart.com/ip/RhinoRamps-Black/19526658?reviews_limit=10&
Walmart has ramps for $8 less. If the difference in quality would matter, I would have no problem buying the AZ ramps but of course if I can save 8 bucks I’d like to.
Finally, I assume I’d also need a wrench. These tools look pretty simple, under $10 at AZ. Are there any brands that folks would recommend I avoid? Any that are better than the others? Or do you folks twist them on/off by hand only?
I have some time to get this organized. I just changed the oil in both, within the last month. I just want to know what to look for, in case I see something on sale.
