I can see the benefit to changing again after storage, particularly if nopt stored in a climate controlled area - because of condensation in the systems.
And that may be a problem to some... but if it is, then there are bigger fish to fry with regards to smaller sump systems that are open, like differentials, where there is an air gap, potential for condensation, etc., and not as much pass through of ventilation once the vehicle is re-started.
If there is a bona-fide need to change the engine oil after storage, then Id be changing everything else too...
I prefer to start off very slow and gently, but end up in a long-drive, getting up to full temperature for all systems, so that moisture can be driven off.
JMH
