- Joined
- Sep 18, 2022
- Messages
- 71
My Ferrari Testarossa has large oil coolers with no thermostat. This is how hot my oil gets after driving 40+ miles at speeds between 80 and 110 mph on a 90F day. I’ve never seen the temp go higher than this. I’m told, by Ferrari techs, this is normal for a Testarossa.
During the winter the needle usually won’t get past the 140 mark. If you let the car idle for a while the oil temperature will rise, but as soon as you start moving the needle will drop back down to the first line.
Is this hot enough to activate the additives in the oil and burn off condensation? I use Mobil 1 15w50 and it holds 17qts .
