I like the car being 'warm', which is basically not hot enough to burn one self with the oil; your pain threshold will determine what that is.
On the cars I can get by with 'ramps' made from pieces of 2x12.
Spread newspaper under the oil filter location in case some oil dribbles out.
I use the Castrol 'engine cleaner' for spilled oil on the driveway (but don't use it on the engine as it's basically oven cleaner).
I drain into a larger shallow drain oil drain pan that has a spout on it, as I can put the oil in milk jugs for recycling and the spout just makes it easier to pour.
I use empty paint cans with a bit of water and soap for oily rags, and also use them for the oil filter, oily newspaper, etc.
If you're using a funnel to add oil make sure it's very clean before using; washed with soap and water and dried.
