Originally Posted By: Vizzy
Originally Posted By: Familyguy
There's no problem adding it now. Be careful of what you let a gaggle of strangers (who have no vested interest in the outcome) "convince" you to do.
A vehicle with such low mileage, even an older one, probably doesn't need any more cleaning than it would get from a good fill of synthetic oil of the appropriate grade.
This is soooo true..
If your engine is operating well, DON'T add ANYTHING EXCEPT WHAT THE MANUFACTURER tell you to..
I get so sick of certain posters constantly recommending Marvel Mystery Oil, AutoRX ,and other snake oil that most likely will not solve a problem, it will likely create a new problem!
If you want to use something with more detergent than a typical gasoline engine oil you could probably get away with using an HDEO oil for diesels like Shell Rotella T for a change, but even then I wouldn't use it too often...
If your engine is doing fine just put in the MFR recommended oil and be happy.
LOL I guess we have something in common. I get sick of posters who never tried a product and bash it, or call it snake oil. A-rX and MMO have quite a following here, and by long time members who seem to know about engines. To each his own I guess.
To the OP A-rX can be added 100 miles into an Oil Change w/o a problem. You can also add MMO 1000 miles before you plan on changing your oil. Cars driven mostly on short trips probably need some kind of cleaning, at least cars I've seen that friends own. Either product won't hurt your engine. Good luck.
