Ok so this is probably my 15th post on my 03 Buick century that I just had the motor swapped in a couple weeks ago. I'm just trying to get this car as rock solid as I can.
Well the original transmission has 192k on it and it shifts better than my civic which has 113k on it. The fluid is rather dark on the dip stick but doesn't smell burnt. There was/Is no service record for the car by prior owner so my guess is as good as yours as to when or if this fluid was or ever has been changed.
So, do I drop the pan and put a filter and fluid back in or just leave good enough alone for now? The car will primarily be a weekend driver on 95% short trips of maybe 10 miles round trip.
Also, there is no sign of fluid leaks g from the trans either.
