Isn't the bottom line here: "One size doesn't fit all?"
In some cases, it would be perfectly fine (even factory approved) to do an "every other" filter change. In others it's not.
Off the top of my balding pate, some red flags that would require consideration would be:
a) the driving environment... a short hopper that generate lots of oxidative residue
b) a tired engine that's generating more than the usual amount of contaminants
c) an engine in a dirty environment
d) a diesel (soot)
e) general engine designs and parameters (like ZeeOSix's)
f) OCI... longer would likely dictate against
g) filter media area... an oversized filter (same efficiency as designed) can hold more contaminants
h) actual PSID test results on something close to your configuration
Wish I had time to do some PSID testing on my engines
d) a diesel (soot)
