Change oil before winter storage with very low miles on oil?
But this is BITOG . You can never change the oil often enough . :p
I’m all for satisfying ones OCD. If you got some sort of compulsion to change it, change it, but don’t dream up reasons that were pulled out of a hat as the reason. Like acidity, or impurities or whatever, that don’t apply to a 250 mile oil.
The proper way to frame it is "do you change the oil before or after winter?" but that is conditional on needing an oil change. If it does need one, you do it before winter. If it doesn't (as I assume oil with 150 miles on it doesn't) then you wait til it has enough mileage to change it the next year.
Change it once a year, from here on, before winter storage. This oil will be fine though for this winter given the low use.
Please don't use BROtella. Yes, it's JASO approved, but that spec is very weak. The tolerance for clutch friction is atrocious. It allows 15% Noack and 50 ml of foam, only requires an HTHS of 2.9 cP (for a 40 grade), and can shear out of grade and still pass. It's such a pathetic spec that it makes API SP look impressive. Rotella doesn't even meet that worthless spec because it produces >50 ml of foam.
suitable oil like Rotella T4 15w40).
You consider this suitable?
The foam is eye opening, however the USA sees 20 billion miles put on motorcycles each year
and within that, many millions of bikes that have run Rotella sure don't have a problem. Haven't seen a Rotella related engine failure in a motorcycle on this forum. With that said, I don't use it at this point but have successfully used it in the past in everything from a 45 year old air cooled UJM (XS1100) to an ST1300 and my current ZRX1200.
The problem with this is reliance on self-reporting which is often unreliable. If someone thinks Rotella is a great oil, they're less likely to consider it a culprit when something goes wrong or something is misperceived as being normal.
There was a drag bike team that was changing bearings every few races on T6 and thought nothing of it. They figured it was normal to go through bearings at that high power level and abuse so they never considered it an issue until they tried a more appropriate race oil. That came about after someone ate the cost of a UOA for him and found over 300 ppm Al. Not only did they find power, the bearings looked good as new after three races with <40 ppm Al in UOA. After a full season of racing, the bearings were still in great shape.
While not a motorcycle application, an engine builder near me was having trouble with valvetrain wear in his high rpm LS builds with solid roller cams. It was particularly harsh on the rockers and pushrods. He was using Rotella or Delvac 15W-40 (whichever was cheaper or available) which he swore was great oil. It's definitely not cut out for 8,000 rpm and >700 lbs spring pressure. He couldn't get 10 WOT hits out of an engine without chewing a pushrod. The bearings, while not destroyed, were less than stellar. For months, he blamed everything but the oil, convinced the oil was great and thus couldn't be the problem. He changed parts suppliers twice, damaged 20+ engines on the dyno, trying to make the problem stop. It finally did when he switched to Driven LS30 with no valvetrain failures since.
I've seen several posts on social media and elsewhere of people complaining about clutch chatter. They mention using Rotella but never consider it the reason. They blame the clutch, the design, the OEM, anything but the oil. "Well, I got good oil in it so that can't be the problem." Bias is blinding. I stick with the science.
I used Rotella T6 in my ST1300 for a few oil changes. Shifting got notchy fairly quickly (after only 1500-2500 miles). I switched to Mobil1 4T, Castrol 4T and Valvoline 4T oils and never had that notchy feeling come back (after more than 5000 miles). I will not use Rotella again for my motorcycles.
Survivorship bias is a hell of a drug.
What would you guys do?
You can't go wrong if you chance the oil or keep it... Either decisions will meet and exceed your mileage expectations because of the low miles...
Here is a story of a Nissan owner defiantly fought the OCI urge and ran
the same 30 grade oil for 122,000 miles... Blackstone labs tested the
oil and gave it more favorable remarks than negative given its
service... the 30 grade viscosity oil was not shear down to a 20 grade
as feared but the actual viscosity tested up more like a 40 grade...
so you might feel relief that missing an oil change interval is not
cause for alarm... Your engine will still meet and exceed your mileage
expectations...
