Not running 20wt or running to the recommended oci fixes both ends of the main problems.Yes and yes - I ran only one OCI of 5W20 (oil cap stamp) when new before switching to 5W30 synthetic full time which was allowed by Hyundai (along with 10W30).
Yes, great call!Make sure you check oil level before you go anyway and when you need fuel.
Good to note - I also failed to share that over the 3,800 miles / 6 months I’ve had to add close to one qrt. of VRP 5W30 make up oil , so there is that as far as replenishing helpful oil ingredients .Yes, run it. You are good.
VRP should be good for at least a year and if cannot make it to 5,000, it would be a shame for all the superlatives we talk daily about it.
I'm currently at 2,000 miles mark with that oil and plan to run it full 5,000 miles because I'm monitoring oil burning for that distance.
Also, we have people on here who have run that oil for 7,500 and even for 10,000 miles.
Was it burning oil prior to Restore and Protect? If it was how much? Have you done the PCV valve? Many have reported an increase in oil burning during 2nd and 3rd runs of VRP that seems to reduce after that. Everyone contributes it to the rings moving some but not being cleared yet, stick with it.Good to note - I also failed to share that over the 3,800 miles / 6 months I’ve had to add close to one qrt. of VRP 5W30 make up oil , so there is that as far as replenishing helpful oil ingredients .
Sound advice. A road trip is the perfect opportunity to run the fuel system cleaner.Going back to my early days of driving till now, If I have a trip, I always keep the old oil in and change it on my return as trips are EZ on oil.
I would check the level and perhaps use this trip to add a bottle of a good POE fuel injector cleaner as I also prefer to use those gas additive cleaners BEFOR I do a fresh oil change. My 2 cents...
I’ve seen differing opinions on this (like everything else I suppose). Some suggest it better/more effective to have the cleaner in for several days/weeks as opposed to running through a full tank in a day or two. Both strategies make sense to me, lolSound advice. A road trip is the perfect opportunity to run the fuel system cleaner.
The oil level will be normal, so will the fuel level. Oh, mighty,!If the oil level is fine, run it and change upon your return.
NOGoing back to my early days of driving till now, If I have a trip, I always keep the old oil in and change it on my return as trips are EZ on oil.
FWIW, I'm a huge fan of Techron Complete but the results only happen in my cases from extended (2hrs minimum) high-speed freeway driving.I’ve seen differing opinions on this (like everything else I suppose). Some suggest it better/more effective to have the cleaner in for several days/weeks as opposed to running through a full tank in a day or two. Both strategies make sense to me, lol
Per Hyundai TSB, mixed normal and severe service calls for a 5500 mile OCI on full synthetic 5W30. I don't sweat it if I approach or run a few miles past 5000 when primarily doing long trips.I think severe service is 3750 miles/ 6 months. Regular service IIRC is 7000 miles / 12 months. Hyundai's definition of severe service is basically owning it (hills, dust, traffic).
As other said based on use conditions, I would run it as is for the trip and change when you get back. Make sure you check oil level before you go anyway and when you need fuel. For a feel good effect and some information for future, pull a sample when you change it and send it in (not Blackstone) and do a C&P of the filter to share.
Do you have a TSB number to share for that? This is on Hyundai website for 2017 Sonata 2.4L for every 3750 for severe service and 7500 for normal. @ChrisD46 probably falling somewhere between there. Also lists fuel additive every 7500 miles. Stock up now on Restore and Protect Fuel system cleaner at Autozone BOGO.Per Hyundai TSB, mixed normal and severe service calls for a 5500 mile OCI on full synthetic 5W30. I don't sweat it if I approach or run a few miles past 5000 when primarily doing long trips.
