Car is a 94 Geo Metro, manual. About 176,000 km on odometer. As far as I know it still has the factory transmission fluid in it... at least I haven't changed it since I bought it in 2001.
My maintenance schedule has some contradictory advice (bolded by me):
"For manual transaxles, fluid doesn't normally require changing. Check the fluid level in the transaxle every time the engine oil is changed. See your owner's manual. Before checking the fluid level, check the transaxle case for leaks. If a leak is found, repair it. Replace the transaxle fluid every 20,000 km (12,000 mi) or 12 months under severe conditions. Under normal conditions, replace the fluid every 50,000 km (30,000 mi)."
So which is it? Never needs changing, or every 50,000 km?
I'm not having any problems shifting so I'll probably leave it alone until I do. But it's been bugging me for a while now.
