Hello all! First let me say I stumbled upon this site about a month ago while researching some oil choices. And it is fantastic!
So, for my first post, I figured I’d ask you all a question
I have a 2007 Fusion with the 3.0L, 30K miles. My current fill is M1 5w20EP with an Amsoil Ea filter. I have had this oil in for almost exactly one year, but fewer than 2K miles. The car is driven at least once a month for 20-25 miles to warm it up and keep a good charge in the battery. What I am wondering is, should I go ahead and change the oil and filter, or will it be ok to keep it in longer? I don’t anticipate many miles on it within the next 6 months, but after that it will be a daily driver again. The previous fill/filter combo was the same, and over about an 8 month period I put just a hair under 8K miles on it.
I tried to pull a sample with a vampire pump from work, but there must be a baffle in the oil pan as I could not get the tube into the crankcase. I do plan on doing a UOA when I change it out. I like the M1 EP so far, but for the next change I have been contemplating possibly using M1 0w20, or maybe a Pennzoil product. I have a couple of Ford Racing FL820S filters lined up for the next few oil changes.
So what is the collective wisdom? Should it be changed out after a year, or will I be fine pushing it a little longer, like 6 months? I have read that the Duratec’s are pretty easy on oil, so hopefully that will play to my advantage.
Thanks!
Thanks!
