Originally Posted By: ZeeOSix
What I'm saying is I don't think the ability of an oil filter to trap water is that important because any condensation from combustion will be taken care of by getting the oil hot and the crankcase ventilation system. How many oil filters have you seen cut open have shown water to be trapped in them? I've seen zero cut open oil filters with trapped water inside because even if it did happen the condensation is usually burned off anyway for the reasons I've stated.
In regards to this... My oil regularly gets to 212-230F and it still has a moisture problem of 500-900ppm of water in the used oil analysis samples so I think that it could be because I'm not using traditional media in my oil filters and using synthetic media.
Yes, I see your used oil analysis here -
LINK
Do you have other used oil analysis on this same vehicle from the same place with any different filters used? Being in the climate you're in up there, it could be a normal reading if you take an oil sample in the winter time with the cold temperatures. Maybe the PCV valve is getting tired - could be other factors involved. There are plenty of used oil analysis posted on BITOG that show low water levels when using full synthetic oil filters, so it's not an automatic direct correlation.
Unfortunately I can't find the first used oil analysis I did at 10,000km to compare. So I only have this one from last October and this one I just did.
I was thinking of doing a used oil analysis on my mom's Journey which is the same engine and see if she has a water problem and then use this to try and figure out what is going on with mine based on that.
It's too [censored] cold to far around with it at the moment. The good news is that the engine isn't showing any wear because of it but it's definitely something to watch.
