E expat Joined May 12, 2009 Messages 5,532 Location Canada Apr 14, 2019 #1 My wifes 2007 Matrix 1800 keeps throwing this CEL in cold weather. I know it is the EV system, but can anyone suggest what the issue is likely to be? I would rather not put it into the dealer. Thanks.
C CharBaby Joined May 25, 2005 Messages 15,688 Location ROCHESTER, NY Apr 14, 2019 #2 I'm missing something here. What is the EV System? Are there any auto parts stores that read codes for free. Here in the states most all of the large chain stores do. This will be a good start. Last edited: Apr 14, 2019
E expat Thread starter Joined May 12, 2009 Messages 5,532 Location Canada Apr 14, 2019 #4 Sorry that is the EVAP system. I have pulled the code PO 2401 (as in the title) but would like some advice on what common reasons might be. I will start with a gas cap 'O' ring as that is cheap and easy, but not sure where to go from there.
Trav Joined Nov 20, 2006 Messages 31,302 Location MA, Mittelfranken.de Apr 14, 2019 #5 Check the cap then make sure the leak detection pump is actually working.
C CharBaby Joined May 25, 2005 Messages 15,688 Location ROCHESTER, NY Apr 14, 2019 #6 Check the fuel filler tube(in the rear wheel well) and the assorted vent lines for rust or broken due to rust.
JTK Joined Aug 14, 2003 Messages 15,782 Location Buffalo, NY Apr 14, 2019 #7 Can you smell fuel vapors anywhere around the tank or filler area?
