For that year/make/model I would certainly check the guide pins. I've got a 99 Grand Am and I would be willing to bet some money that they didn't change too much brake wise by 2003. Other than sheet metal I think they are similar in bones. I've had to replace the entire bracket/pins/boots twice on this car because they seize up. Also had to put new calipers on both sides. They sell fully loaded calipers on eBay for pretty cheap. Just had 2 rotors that came with a set of Powerstop Ceramic pads delivered from eBay for $42 and that includes shipping. Definitely check eBay out!
Overall, I think the braking system sux big time in this car and it always has. Even with all the work I've done. Had the brake fluid flushed once and bled a few times by the shop as well. I don't drive it on the highway because I don't want to risk the safety of others nor myself. It's just an around town beater to keep the miles off my new car.
heres a question.. Should slider pins be re-lubed at some point between pad changes? I ask because on my 2010 mazda 3 I never touched the brakes once in the 115k miles I owned it.
Considering the relative ease of disc brake work I don't think it could ever hurt. Especially if you live in an area where they use salt in the winter. I tear mine down annually and wire brush the pins down clean and clean out the pin holes and guide pin boots. And I always use: https://www.amazon.com/Permatex-80078-Anti-Seize-Lubricant-Bottle/dp/B000FW7VGE
Brake hardware is cheap. It just makes sense to replace the boots/seals, pins, guide plates with the pads. It seems when I would cut corners and not do hardware that's when issues would occur. but with new hardware all goes well...
On GM cars the number one culprit for poor brake pad life is the hardware. The pad hardware should be changed every time the pads are changed. But most do not get changed. They rust and do not allow the pads to move freely. Change the hardware and apply brake lube where the pad touches the hardware and your problem should be solved
