Originally Posted By: CATERHAM
Of course that's what I'm rationalizing! If it wasn't OK, we'd be forced to stick to a particular brand/blend.
[/quote]
And that is the whole point, it is totally OK to change brands, top up with with another brand or blend to your hearts content.
I've quoted what Castrol says on the practice before but I'll quote it again because I don't know of a formulator that doesn't share the same viewpoint:
"Syntec is a fully formulated, super premium motor oil and is fully compatible with all conventional and synthetic motor oils.
Mixing Syntec with a premium oil will improve the performance of the oil and not harm your engine in any way. However, by diluting Syntec, you also dilute its effectiveness. We recommend that you use 100% Syntec every time you change your oil to get the maximum benefit."
The fact that you don't appreciate the practice except on your terms and don't fully understand the concept of operational viscosity is fine but one has to wonder why you and a few others so vehemently ridicule those that do .
I suspect it's a simple case of jealousy. One thing's for sure, you certainly don't believe in a live and let live policy with those that don't share your viewpoint.
I've never ridiculed anyone for sticking with the same brand, following OEM recommendations to the letter or even recommended a blend to someone that wasn't already interested.
[/quote]
