Propflux01
$100 Site Donor 2026
Waht are pros and cons of one? Does anyone know of an actual comparison between engines with and without one?
Instead of posting one video, I posted the link to catch can videos so you can see the results for yourself.Waht are pros and cons of one? Does anyone know of an actual comparison between engines with and without one?
I've seen a pics of some catching a lot of moisture, but judging by the color, in the summer at least mine are catching mostly oil.If the question is...what does valve cooking look like with or without a catch can...good luck finding actual photos and evidence, because unless I’m missing something, there really hasn’t been longterm documented evidence to compare. Why not? I have no idea, but I imagine catch can companies aren‘t financially secure/big enough to purchase two vehicles (new) and run them 50,000 miles and compare the two? Either that or they are afraid the evidence will be disputed, or not be “enough evidence”?? maybe people would look at the photos and question it, or not see enough benefit at all?
But I do think they help - I don’t think it’s super major “help”, but I do think they catch oil vapor a bit and water. Some will argue that they are not doing much of anything, that the “oil” being caught in that can is mostly water due to the temperature differences of the can and crankcase (causing vapor). Some will argue that water that is caught in that can would actually help clean the valves. Personally I think they DO HELP. I ran one for two years and yes, in the winter you do catch a lot of water, but it still has oil in it. In the summer overall everything was much less...oil and water. Mine never froze up...I was always careful about emptying it. I wouldn’t go out and buy an expensive one, you can get a $30 dollar can on amazon and the reviews on the can are quite excellent (build quality, design, effectiveness). The companies that build $200-$300 cans will tell you theirs is “better”, and they probably are, but that $30 dollar can will collect lots of oil. Trust me.
I’ve seen many of those, but what I haven’t seen, is say two engines with similar mileage, one with A can, one without. And actual side by side valve comparisons to each other.Instead of posting one video, I posted the link to catch can videos so you can see the results for yourself.
https://www.youtube.com/results?search_query=CATCH+CANS
The design appears to be able to collect condensation when cool and then fully warmed up evaporates it into the intake.
On low tech vehicles, I've used a catch can before. On high tech vehicles with very advanced systems, like my Mazda's, I have not. Honestly, no real difference in any of it, although some vehicles have known issues and I would recommend one for those, and if you own one, and are on THIS forum, you're probably already aware of the issue.
True I suppose. I put 100k miles on my last mazda di with no issue related to this though, sans can.several vendors make catch cans for the Mazda DISI motor (corksport, mishimoto, damond, JBR). I’m not running one but there are people that swear by them and they don’t seem too difficult to run.
100k is pretty low though. My 2 cars didn't get a catch can until way over 200k in hopes that it will reduce carbon buildup as they go past 300k. I'm putting a catch can on my 05 Silverado at 200k/8700 hours, no issues with it so far, but I'm more worried about 300k.True I suppose. I put 100k miles on my last mazda di with no issue related to this though, sans can.
I've only seen 430k miles out of a chevy 5.3. No catch can. Was still running alright. Dads workvan. Body rotted around the engine and transmission. Not a knock against it, it is expected for what it was used for.100k is pretty low though. My 2 cars didn't get a catch can until way over 200k in hopes that it will reduce carbon buildup as they go past 300k. I'm putting a catch can on my 05 Silverado at 200k/8700 hours, no issues with it so far, but I'm more worried about 300k.
I'm not saying it's required at all to make it that far, especially in a port injected engine, just that it can't hurt. My engine has 8700 hours also, so lots of idling and equivalent to over 500k miles of easy highway use. It burns a bit of oil through the valve seals. I'm not saying it couldn't make it to 430k miles without, but it's way to easy to throw a catch can on, just for the peace of mind.I've only seen 430k miles out of a chevy 5.3. No catch can. Was still running alright. Dads workvan. Body rotted around the engine and transmission. Not a knock against it, it is expected for what it was used for.
