I have a 2003 Ranger 3.0l that experienced a catastrophic overheat that resulted in new head gaskets and reworked heads.The vehicle lost all coolant at once and was driven till it died. Due to the lack of coolant the temp on the gage did not rise and the dark foggy weather kept the mist from being visible. As a result of this my compression numbers are a little low.
CYL #1--- 160
CYL #2--- 156
CYL #3--- 161
CYL #4--- 160
CYL #5--- 146
CYL #6--- 165
I am attributing this to coked up rings from the overheat. My plan is to run 1 qt of MMO and 4 qts of 5w30 in the crankcase. Run MMO in the fuel at 4 oz per 10 gal for the entire OCI. And finally spray some MMO into the cylinder through the spark plug hole and let it sit at least overnight. It is my hope that this will clean the rings and lands and free them up. After the 3000 mile OCI i will do another compression check.
What do you all think?
Is the MMO thin enough to slide past the cylinder by itself if sprayed into the cylinder? Should I cut it with a little seafoam? I know it is thin but piston clearance is also pretty tight.
CYL #1--- 160
CYL #2--- 156
CYL #3--- 161
CYL #4--- 160
CYL #5--- 146
CYL #6--- 165
