Originally Posted By: cfromc
My theory is that a combination of factors killed this engine. There was poor filtration by the filter and/or a loose fitting in the intake tract, the oil was not changed anywhere close to every 3K, the radiator was not providing enough cooling, the oil was run extremely low (2-3 quarts low), the engine suffered additional stress due to the oversize tires, and the engine was routinely flogged to high RPM while mudding.
The interior and exterior of the vehicle, while not a factor in this theory, certainly give the impression of an abused vehicle.
Wow. Are you really stating that oversized tires are a factor relative to running 3 qts low on oil?
I would have thought that a warranty claims investigator (I believe that title is correct) would not consider the interior or exterior of a vehicle on whether to deny or grant a warranty claim. However, I think that you are only saying this to prove that he was mudding in the pickup & not as a general statement of this vehicle was never washed or cleaned so they probably don't take care of the maintenance. Right?
If it can be proven that the vehicle was run 3 quarts low of fluid, how is the warranty not immediately denied barring massive oil leaks from other faulty components that are under warranty? Did the low oil light not come on?
