Before I do this drain and fill on my wife’s 2013 Honda fit, is there anyone on here who has used the Castrol universal atf/cvt fluid? I’ve used Valvoline maxlife in the past, just curious about this Castrol offering
I have used it in a Mitsubishi Mirage CVT - worked fine and I consider it equal to Maxlife. I mostly use Maxlife but on occasion I will use the Castrol as well as it is often a few bucks cheaper. Use it with confidence.Before I do this drain and fill on my wife’s 2013 Honda fit, is there anyone on here who has used the Castrol universal atf/cvt fluid? I’ve used Valvoline maxlife in the past, just curious about this Castrol offering
Is there a chance the transmission has some issues and maybe was not the fluid? I agree that when in doubt the OEM fluid spec is the better choice - but having used Maxlife in so many different applications in my shop with no issues I will continue to use it where I know it works but there are definitely certain applications where you want a specific OEM fluid spec over universal.I used Maxlife ATF in my old Nissan AT, and it never shifted properly again. Since then, I only use OEM recommended fluid in AT's. I don't know what fluid is recommended in your Fit, but the safe choice, is the OEM Honda fluid.
No atfIs your Fit a CVT?![]()
No atf
And that is a JATCO CVT transmission.I have used it in a Mitsubishi Mirage CVT - worked fine and I consider it equal to Maxlife. I mostly use Maxlife but on occasion I will use the Castrol as well as it is often a few bucks cheaper. Use it with confidence.
Plus from what I think I've seen, Castrol is huge throughout the rest of the world. Here in the US, Valvoline seems to have more of a presence but Castrol seems to be more of a "world" company.I have used it in a Mitsubishi Mirage CVT - worked fine and I consider it equal to Maxlife. I mostly use Maxlife but on occasion I will use the Castrol as well as it is often a few bucks cheaper. Use it with confidence.
I agree, but I think the OP has a step shift.Specific or dedicated cvt fluids such as HPL CVT, Amsoil CVT, Redline CVT, and Valvoline CVT seem better choices in my view.
You're right, OP finally clarified that in Post #7.I agree, but I think the OP has a step shift.
Sort of.OP finally clarified that in Post #7.![]()
And rightfully so, especially from HPL, AMSOIL, and Redline. They have much better basestocks and additive packages.Specific or dedicated cvt fluids such as HPL CVT, Amsoil CVT, Redline CVT, and Valvoline CVT seem better choices in my view.
