Hi guys,
It's been a while since I last posted.
I drive a 2008 Chevrolet Impala with the 3.5L Flex-Fuel engine.
I routinely run Pennzoil/Chevron 5W-30 Dino following the OLM down to 0-5% which here in warm Tucson can be up to 12500 miles if all driving is warmed up freeway driving.
Although GM feels the Dino is adequate in this low output 211hp engine (no 4718 oil specd here), I figure a good Group III synthetic should give me a little more TBN reserve and cleaner engine, especially near the end of the OCI.
I wanted a thin 5W-30 for max economy, with good specs, and won't push the OCI past the OLM limit so Amsoil SSO wouldn't be cost-effective IMHO.
I'm Leary of the high Fe issue with Mobil 1 and again I don't think Mobil 1 EP (fine oil that is) is worth the $6-7 extra at WalMart if I don't keep it in for 15-18k (the same for Castrol Edge which is still going for $26.50 in my WalMRts)
Today I narrowed my choice down to two oils, Castrol Syntec & Pennzoil Platinum . I know that the Syntec is 9.7 st@ 100c. vs. 10.3 for PP.
Both are loaded with additives so both should keep this engine clean with the 10-12k OCIs I run (sounds long but within the proven limits set by the vaunted GM OLM).
So I buy the Syntec today partiaaly because thus WalMart was out of the PP 5W-30. Then I checked the specs and was surprised to not see 4718M. I know I don't need it but that spec along HTO-06 are nice protection regarding high temperature deposit protection which can't here in 110-115 summer weather driving up to Phoenix mjltiple times/ week. I know that my oil temperature probably doesn't get high enough to require it, but again it would be nice to have.
Should I return the Castrol Syntec 5W-30 for the PP 5W-30? What do you think?
Take care,
Gary
Take care,
Gary
