Originally Posted By: Doog
Originally Posted By: Robenstein
That is what I am running. Bike likes it better, I just let it warm up a bit more.
I think I will go to the 20w50 after I use my 10w50 I have. I just wondered what the difference is between the SL & SJ thing?
Thanks Doog for pulling the technical specs of the oil from Castrol
To be honest there's not a wide variance between the API specs of SJ/SL. The primary differences occur with the newer SL spec that included the addition of Sequence VE (another cam wear average test), along with Sequence VG (characteristics of oil in different conditions); along with the tightening of some performance criteria. Otherwise, the API SJ/SL designations are very similar in testing methodology and their results.
http://www.aftonchemical.com/Lists/Brochure/Attachments/40/Specification_Handbook.pdf
(pages 28-29)
Besides their API rating, they are apparently rated JASO MA2 and both have passed all of JASO's testing requirements to meet that certification; meaning in theory, they are relatively equal as far as performance. The biggest differentiation between them is their relative viscosities, and that's where I'm very interested in what used oil analysis or technical information the dealer asserts that the 10W50 will be equal to or more shear stable than the 20W50. The 10W50 will have more viscosity index improvers than the 20W50, and having higher amounts of VII's increases the chance of them being disfigured/elongated (shearing), which in turn can cause the viscosity to either temporarily or permanently shear to a lower grade as has been shown in a wide variety of the used oil analysis posted here on BITOG.
I'd also run the 20W50 as you suggested, not only because of the shear stability, but also because of the price; especially since a 20W oil will take you down to a 32F startup temp. I think the main reason the 5W40 and 10W50 oil cost as much as they do is simply supply and demand (less of a product, cost goes up) and simply because it's more of a unique viscosity whereas 10W40/20W50 are more common.
http://www.api.org/certifications/engineoil/categories/upload/motor_oil_guide_2010_120210.pdf
(bottom page)
