Castrol Import Multi Vehicle ATF
Interesting that this fluid meets ATF+3, but not +4? Must mean that this is a mediocre fluid... and that the fluids it is spec'd for fall in the same boat??
Nope, import ATF is not a full synth. Castrol already sells a full synthetic ATF+4. Most of the import fluids are mineral only, and some of the better ones are blends. There is no need to produce a full synthetic import ATF when a blend easily meets all the specs.
There is also some exclusivity with licensing. Since Castrol has a licensed ATF+4, I doubt that they can sell an unlicensed equivalent at the same time. You also won't see any other ATF spec's on ATF+4. I would wager that ATF+4 would blow through most other standard domestic and imported ATF spec's without a problem.
'I would wager that ATF+4 would blow through most other standard domestic and imported ATF spec's without a problem'.
I've warned you before about wagering!
I have a '95 Accord and '97 Galant that I want to start doing regular drain and fills on. Is it unwise to use the Castrol Import ATF in place of the more expensive (assumed) Z-1 and SPIII? Or is the Castrol truly equivalent or better in composition and performance?
Besides, I think SPIII is only available in bulk from the dealer here.
