Castrol Edge valvetrain noise???
Originally Posted by 2015_PSD
Originally Posted by ChrisD46
For a quieter engine try Mobil 1 next time ...
In bound post that M1 makes engines louder in...3....2....1
Here it is.
I was told that Ford had to send another memo and a DVD to explain what a typewriter is ... as it can be confusing for the younger crowd!
Originally Posted by Falcon_LS
Originally Posted by bdcardinal
From Ford:
SSM 47787 - 2011-2019 Mustang/F-150 - 5.0L - Tick Tap And/or Typewriter Noise At Idle
Some 2011-2019 Mustang and F-150 vehicles equipped with a 5.0L engine may exhibit a ticking noise at idle after an engine oil change. It is often referred to as typewriter noise because of its similarity to the sound of a mechanical typewriter. The noise in question may be heard on some engines when engine temperatures reach 150°F (65°C) or higher and engine speed is at idle up to approximately 1700 RPM's. It can typically be heard at the front wheel well, and is often isolated to the transmission bell housing or oil pan area. typewriter noise is not detrimental to engine function or durability and has no short or long term effectson the engine. This an operating characteristic of the 5.0L engine and no repairs should be attempted.
APPLICABLE VEHICLES
2011 - 2014 TRUCK: F6 F150/LINCOLN MARK LT
2018 - 2019 TRUCK: FC P552N F-150
2015 - 2017 TRUCK: FC P552N F-150
2012 - 2013 CAR: ZF S197N MUSTANG
2011 - 2014 CAR: ZF S197N MUSTANG
2019 CAR: ZG S550N MUSTANG
2015 - 2019 CAR: ZG S550N MUSTANG
Wow, this is the single biggest complaint I hear whenever I take the Mustang to the dealer for service. An "operating characteristic of the 5.0L engine and no repairs should be attempted"?! Touch wood, I haven't had this issue yet.
I have a feeling I know what you aren't having that issue.
From Ford:
APPLICABLE VEHICLES
The Ford V8 Coyote "Typewriter Tick" (aka the "BBQ Tick") is very random in frequency and more pronounced in the bottom end of the motor, it's not valve train noise. Just search "BBQ Tick" on YouTube if you want to hear what the ticking sounds like that the Ford SSM is addressing.
Mine has done it since new and it is in the valvetrain. My car has seen nothing but 5W50 since it is a Track Pack. The older 4.6 and 5.4 DOHC engines would do it from coolant pooling in the rear of the head and not having an outlet. There would be excessive valve guide wear which was addressed with updated cylinder head castings, 2C5Z-6049-BAB and 2C5Z-6049-CAB.
