Whoopdie doo? Dude, you have 6,000 miles on the engine, it's clearly still breaking in. What were you expecting? This is why we don't do UOA's on new engines. This report tells you nothing other than you have significant fuel dilution, which you were clearly already aware of.
Your iron is at 6 @ 2,090 miles, universal averages are 14 @ 7,200 miles. Aluminum is 5 and 5. These ppm counts are so low they are likely noise.
Your iron rate is 2.87ppm/1,000 miles
UAV iron rate is 1.94ppm/1,000 miles
That is NOT 3x. It isn't even 1.5x.
Your aluminum rate is 2.39ppm/1,000 miles
UAV aluminum rate is 0.69ppm/1,000 miles
Yes, that's 3.46x higher. Again, noise, this is an engine breaking-in, it means nothing.
