Castrol Edge Euro Car 5w-40 VOA
API SP
ACEA A3/B4
LL-01
MB 229.5
A40
RN0700/RN0710
VW 502/505
I mailed the sample to Oil Analyzers Indianapolis on Monday and received the report by Wednesday. On my submission form I did not include product brand or information. Only product viscosity grade.
The TBN is lower than Mobil 1 Euro 5W-40, along with less B and Mo, though with a touch more ZDDP. This oil recently sheared -13.66% in KRL, shearing down to a 30 grade in both KV100 and HTHS.
HPL No VII 5w30 (y)
Terrible results for the Castrol. I'd stay away from that oil. One could argue though that it meets some demanding specs.
Why is everyone trashing the oil, what's wrong with the report? Standard SP add pack that everyone uses, with high viscosity. A lot of 5w40 SP oils are down to 13.5cst now. Maybe they shear down to the same point, but wouldnt you want the one with higher viscosity anyway? This is assuming the 5w40 will be used in a higher than average power output engine, with mpg not an issue.
I had an oil burning monster, threw everything at it, and often. My memory says Castrol consumed less than a lot of other favorite brands. No used oil analysis or anything, take it for what you will, but it was on sale often and always in stock. If you change it often, how do you lose?
It’s mediocre looking on paper vs its competitors, but it is cheap so there’s that. It’s perfectly good in any applicable Euro car.
API SP
ACEA A3/B4
LL-01
MB 229.5
A40
RN0700/RN0710
VW 502/505
Here is my report on the same oil (also API SP) from 2023.
Main differences:
-Moly cut in half
-more silicon and sodium
-higher viscosity
-lower base number
-slightly higher starting oxidation
I am going to respectfully value RDY4WARS thoughts. He speaks the truth.
Although Castrol 5w-40 is not the best off the shelf offering it's at least cheap at $23.97 on walmart shelves and it does meet porsche a40 for that price so there's far worse that can be poured in an engine. But both M1 and Castrol 0w-40 are better than it but it's far from bad.
Yes, but 0W40 is the same price on Amazon.
I respect everyone's opinions and experience, but the voa report with its viscosity at 14.6, with a little moly and low calcium for lspi, AND the lowest price on the shelf when on sale here.....I grabbed 3 jugs and started using it on the audi. 3.0t single pulley stage 2 tune. Plan on changing it under 5k km. Will report on the the UOA when it comes. The previous was motul xcess 8100 api sn. 5w40. It was LOADED with moly, 300ppm or so, as well as calcium 3000ppm. Started at 14cst or so, was still in grade 12.5 when changed. Was mostly winter driven,
, in Toronto, with short drives, fuel dilution was a bit high as expected but still in the 'green' for.the report. Same as iron. But the car ran strong, good fuel pressure I assume. Anyways, ill report on the castrol when its time. Take care and let's see what the reports say.
He is mostly likely more knowledgeable than I, however, id like you remind everyone what lake speed jr said. Fourmulas change without notice. What that chart says at that time, doesn't nessesarily mean its the same formulas as the bottle in our hands now. One voa report says 13.5 cst , and another 14.6. Are the labs not accurate? Or are the companies changing the formulas? He says they do that. The only way to know exactly is to test the one in your had at the time, right?
I actually like the Castrol results. It compares favorably to Mobil 1 0w-40. Higher post-KRL results for both viscosity and HTHS. Yes, percent numbers are slightly worse, but too close to call. The only oils on the charts that perform significantly better are the high cost boutique oils.
I would *love* to see this chart filled with every off-the-shelf oil brand and grade. That would be incredible!
