Castrol 5w-50?
New York
Has anybody used Castrol 5w-50 in a motorcycle? Kawasaki 500 in my case, watercooled, been running Rotella 5w-40 synthetic. I was in WalMart last night and they had 4 quarts of Castrol 5w-50 on sale for $4.50 per qt., which isn't a super bargain but still works out to less than they're charging for a gallon of Rotella synthetic right now. Thought I might try this in my motorcycle for the summer. Thoughts?
I have used it in years past in my Ducati 900SS[shared gearbox, dry clutch]and it seemed to perform just fine although the change intervals were probably pretty short. Also, the formulation that I used was probably SJ or SL as opposed to the current SM formulation.
Here is the only used oil analysis that I could find for a motorcycle:
http://www.bobistheoilguy.com/forums/ubb...true#Post721750
PS - If it says "energy conserving" on the back of the bottle, it contains friction reducing additives that may mess with the function of your wet clutch.
Rotella has no FRA.
IMHO, Rotella T 15-40 is cheaper still than this Castrol you speak of and probably better for your bike, so if you want to save more money, I'd go with RT 15-40. either way, I"d say the Rotella is the best way to go. RTS is only a couple bucks more and probably a much better bike oil.
I wouldn't expect to see a 50 weight HDEO from Rotella as the trend is towards lighter and lighter oils in both cars and trucks. I wouldn't be surprised if in a few years we look back on 40 weights as dinosaurs.
if you want a 50wt look no further than Valvoline VR1 sae50. it's pretty darn good. their VR1 20w50 is pretty darn good as well!
Keep using the Rotella. Its cheaper and more easily available. I would be willing to bet its every bit as stout as the Castrol if not more.
You dont need a 50 weight in a water cooled bike. You could run Kendall GT1 20w50 as it is the only grade with high zinc still, or you could run 15w50 Mobil 1 for other off the shelf varieties of oil.
In my BMW R1150GS the 40W can't handle the 100+ temps, currently running Amsoil 20W50...just interested in something more convenient and cost effective.
Didn't mean to get off topic.
