slo town
$200 Site Donor 2026
Hello:
I've been using German/Belgium Castrol 0w30 for years on both our BMWs, and more recently on our Passat VR6 (for it's first couple of OCIs).
As must of you know, 0w30 no longer has BMW's LL-01 approval. As I understand it, it's because BMW LL-01 oils can no longer be 0W-xx. Doesn't matter. Even with the lack of a LL-01 approval, that won't stop me from using it. I think the "Euro" Castrol 0w30 is good oil and I have several used oil analysis from two cars to prove it.
Anyway, I recently ordered two cases from Amazon. Although I've ordered it from Amazon before, for this order I wanted to make sure I didn't get counterfeit oil. That's why I did this VOA.
I'm certain the oil I got is the real thing, although the formula has changed since my last 0w30 used oil analysis/VOAs. The ones I tested in 2014 were the LL-01 versions. This latest 2020 is not. That said, this doesn't mean the LL-01 approved formula hadn't been changed since my earlier used oil analysis/VOAs.
Where before the oil had the somewhat balanced Ca/Mg add pack, the new version has the high Ca/low Mg that seems to be in vogue now days. In fact, it looks a lot like the 0W-40 Castrol Passat VR6 used oil analysis I just posted, just thicker.
https://bobistheoilguy.com/forums/t...0-5k-oci-2016-vw-passat-vr6-20k-miles.334095/
And then TiGeo just posted a VOA of Castrol 5W-40. Same add pack combo.
https://bobistheoilguy.com/forums/threads/castrol-edge-5w40-voa.333766/
What I see here is that Castrol's A3/B4 oils (0W-30, 0W-40, and 5W-40) have the same add packs now.
The first VOA is from Nov 2020. The other is from Nov 2014. This is not cause for alarm. It's just an FYI for "German Castrol" users.
Enjoy,
Scott
Enjoy,
Scott
