On all vehicles with these type of filters,is the bypass/anti-drain back options that are found in the "can"style filters just built into the vehicle? If that is true, then changing the brand of cartridge filter you use would probably have no effect on start up noises right? Reason I ask is that my 2010 Camry (2.5L) has noticeable start up noise for about 1/2 a second and then vanishes (I assume when oil pressure builds up to the noisy part, which I think is the cam timing devices)
Or am I incorrect and do you think changing the filter element would make a difference? Thanks.
