Carbon on Intake Valves-in Carbureted Engine?
US
I have some serious engine problems in my MG, starting with my head and working down. The short answer now is that I'm waiting both for a replacement head to replace the boat anchor(visibly cracked) on it as well as for a machine shop to bore it.
In any case, though, we hear a lot now of carbon on GDI engines, but I was always under the impression that gasoline washing over the intakes kept them relatively clean.
This cylinder head was redone about 5K miles ago. The original intake valves were reused, but were spotlessly clean and were lapped to the re-cut seats. I think there were some issues with how the work was done, but that's another topic and something I'm discussing with some MG guys. I'm doing a "post mortem" on the head, and pulled one set of valves.
I'm a bit surprised at the amount of carbon on this intake valve(on the right in the below photo) especially given 5K miles. Any thoughts on what could have caused this? I did have a fair bit of blow-by, but ran both a cleaned/refurbished factory oil-air separator and a catch can(that didn't catch a ton) so don't think I had much if any oil going into the carburetors. It's always run on 92/93 Octane gas, and usually Shell V-Power. I do Berryman's B-12 once a year or so. Every tank also gets Sta-Bil, more because I don't know if I'll run it out in a week or in 3 months.
New cast iron guides with "umbrella" type oil seals.
I can't deny the occasional period of rich running, but the last tune-up I did had the plugs a nice light tan color so it wasn't overly rich.
Carbon on intake valves was seen sometimes back in the day, sometimes to the extreme and cutting power like a blocked exhaust...we used to chip it off the valves in place if need be. But it was not common on BMC engines...although what you show would be considered ''normal.'' At the time we put it to oil running down the inlet guide.
Sloppy valve guide reaming at the machine shop.
That's definitely from oil running down the guides.
Good luck - - I have butted heads with machine shops over the exact same issue - only 10,000 miles and even worse carbon than that!
Thanks!
Unfortunately, I'm not dealing directly with a machine shop on this.
I bought the head prepped and supposedly ready to bolt on from someone who "worked part time at the machine shop" and claimed to have done dozens of MGB heads. He's an MGB owner himself.
The carbon unfortunately is the least of my problems on this boat anchor...
